Writing technical content in Academic
Image credit: John Moeses Bauan
Academic is designed to give technical content creators a seamless experience. You can focus on the content and Academic handles the rest.
Highlight your code snippets, take notes on math classes, and draw diagrams from textual representation.
On this page, you'll find some examples of the types of technical content that can be rendered with Academic.
Examples
Code
Academic supports a Markdown extension for highlighting code syntax. You can enable this feature by toggling the highlight option in your config/_default/params.toml file.
```python
import pandas as pd
data = pd.read_csv("data.csv")
data.head()
renders as
import pandas as pd
data.head()
Math
Academic supports a Markdown extension for $\LaTeX$ math. You can enable this feature by toggling the math option in your config/_default/params.toml file and adding markup: mmark to your page front matter.
To render inline or block math, wrap your LaTeX math with $$...$$.
Example math block:
$$\gamma_{n} = \frac{
\left | \left (\mathbf x_{n} - \mathbf x_{n-1} \right )^T
\left [\nabla F (\mathbf x_{n}) - \nabla F (\mathbf x_{n-1}) \right ] \right |}
{\left \|\nabla F(\mathbf{x}_{n}) - \nabla F(\mathbf{x}_{n-1}) \right \|^2}$$
renders as
\[\gamma_{n} = \frac{ \left | \left (\mathbf x_{n} - \mathbf x_{n-1} \right )^T \left [\nabla F (\mathbf x_{n}) - \nabla F (\mathbf x_{n-1}) \right ] \right |}{\left \|\nabla F(\mathbf{x}_{n}) - \nabla F(\mathbf{x}_{n-1}) \right \|^2}\]
Example inline math $$\left \|\nabla F(\mathbf{x}_{n}) - \nabla F(\mathbf{x}_{n-1}) \right \|^2$$ renders as \(\left \|\nabla F(\mathbf{x}_{n}) - \nabla F(\mathbf{x}_{n-1}) \right \|^2\) .
Example multi-line math using the \\ math linebreak:
$$f(k;p_0^*) = \begin{cases} p_0^* & \text{if }k=1, \\
1-p_0^* & \text {if }k=0.\end{cases}$$
renders as
\[f(k;p_0^*) = \begin{cases} p_0^* & \text{if }k=1, \\ 1-p_0^* & \text {if }k=0.\end{cases}\]
Diagrams
Academic supports a Markdown extension for diagrams. You can enable this feature by toggling the diagram option in your config/_default/params.toml file or by adding diagram: true to your page front matter.
An example flowchart:
```mermaid
graph TD;
  A-->B;
  A-->C;
  B-->D;
  C-->D;
renders as
graph TD;
  A-->B;
  A-->C;
  B-->D;
  C-->D;
An example sequence diagram:
```mermaid
sequenceDiagram
  participant Alice
  participant Bob
  Alice->John: Hello John, how are you?
  loop Healthcheck
      John->John: Fight against hypochondria
  end
  Note right of John: Rational thoughts <br/>prevail...
  John-->Alice: Great!
  John->Bob: How about you?
  Bob-->John: Jolly good!
renders as
sequenceDiagram
  participant Alice
  participant Bob
  loop Healthcheck
  end
An example Gantt diagram:
```mermaid
gantt
  dateFormat  YYYY-MM-DD
  section Section
  A task           :a1, 2014-01-01, 30d
  Another task     :after a1  , 20d
  section Another
  Task in sec      :2014-01-12  , 12d
  another task      : 24d
renders as
gantt
  section Section
  section Another
  another task      : 24d
Todo lists
You can even write your todo lists in Academic too:
- [x] Write math example
- [x] Write diagram example
- [ ] Do something else
renders as
  • Write math example
  • Write diagram example
  • Do something else
Tables
Represent your data in tables:
| First Header  | Second Header |
| Content Cell  | Content Cell  |
renders as
First HeaderSecond Header
Content CellContent Cell
Asides
Academic supports a Markdown extension for asides, also referred to as notices or hints. By prefixing a paragraph with A>, it will render as an aside. You can enable this feature by adding markup: mmark to your page front matter, or alternatively using the Alert shortcode.
A> A Markdown aside is useful for displaying notices, hints, or definitions to your readers.
renders as
Did you find this page helpful? Consider sharing it 🙌
Avatar
Dr Sonia Boender
Health Scientist & Field Epidemiologist
Public Health Research & Infectious Disease Epidemiology.
